CiscoWorks Topology
caioamonteiro
Hi Guys,
I have recently installed CiscoWorks 4.0 to easily manage our network, but Im having some problems to use the Topology Service.
When I try to start it at Configuration > Topology, I receive the following message:
The CiscoWorks ANSI database engine service is started. I tried to do the same directly from the server, but the error keeps happening. I changed the certificate to the IP, but didnt work. Could someone help me?
Thanks and Kind Regards,
Caio.
Hi Caio,
Kindly replace the attached ANIServer.properties file with the Existing one . Make sure you have all the required premission on this file.
Note :Keep the backup of Existing file
Then Restat the ANIServer as below:
pdterm ANIServer
pdexec ANIServer
Now check the status with pdshow ANIServer ,it should be Running with busy flag set
If it is then Try to launch the topology and I hope it should work..
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
10 Replies 10
AFROJ AHMAD
Hi Caio,
First all geneate the certificate back with HOSTNAME of the server.
then make an entry in the HOSTS file  ( location :c:\WINDOWS\system32\drivers\etc)
For e.g :
x.x.x.x
Now try to launch the topology and see how it works..
In case above did not help send me the output of pdshow and Java consle debug.
Afroj
Hi Afroj,
First thanks for helping me.
I tried but didnt work, and Im not finding the Java Console and even not the pdshow. Could you help me once more telling me where to find'em?
Thanks and Regards,
Caio.
How to turn on Java Console for Internet Explorer:
Enable show Java console window. Do this under.
Settings> Control Panel> Java Plug-in> Basic Tab> Java Console> Show console.
From the Menu select Tools --> Internet Options --> click the Advanced Tab --> Under the subheading of Microsoft VM click on Java console enable -->  click ok --> Go back to the General tab and click on "Delete
Files..." --> now exit and restart IE.   After restarting IE --> go to View from Menu --> Java console --> this will pop up the Java console window -->   Inside the Java console press the number 5 (turn on higher level logging)
Now mimic the process that we need the debug for. (that means open topological services)   Capture the output of Java Console, and send it to me in a text format.
for the output of pdshow :
go to command prompt on server : >>type : pdshow >pdshow.txt
and send me the text file..
Afroj
Hi Afroj,
Sorry for late on answering.
Here go the both outputs attached.
Thanks and Regards,
Caio.
Hi Calo,
Topology service will not work as ANIServer is down..
Process= ANIServer
State  = Failed to run
Have you installed any Device pacakges update recently..?
send me the below files:
Aniserver.properties   and
Aniserver.properties.ORIG    (Location:NMSROOT\CSCOpx\campus\etc\cwsi)
Afroj
Hi Afroj,
No, I just installed CiscoWorks.
Attached are both files.
Thanks and Regards,
Caio.
HI Caio,
what is NMSROOT of the server ?
like c:\program files\CSCOpx
Afroj
Hi Afroj,
Yeah, NMSROOT = C:\Program Files\CSCOpx
Thanks and Regards,
Caio.
Hi Caio,
pdterm ANIServer
pdexec ANIServer
Afroj
Hi Afroj,
Topology is working now!
Thanks for helping me and Best Regards,
Caio.
