09-21-2011 08:29 PM
Does DFM 3.2 support Nexus 5548? I am seeing it as "Unknown Device".
Below are the packages that I have.
1. | DFMDeviceUpdates | 19.0 | Device Fault Manager Device Package |
2. | DFMSharedUpdates | 3.0 | Device Fault Manager Device Package |
Thank you.<BR type="_moz" mozdirty></P>
09-21-2011 11:41 PM
Hi ,
yes ,Nexus 5548 is supported in DFM 3.2.
make sure the IOS Image should be atleast :5.0.2.N1
Afroj
09-22-2011 01:55 AM
DFM 3.2.0 and NX-OS is 5.0.2 N1. Still DFM shows the 5548s as Unmanaged.
Thank you.
09-22-2011 04:27 AM
HI,
Is the Device managed properly in other application like RME etc...?
Are you using SNMPv2 or SNMPV3 ?
Try deleting and readding the Devive in DFM and see how it works..
Afroj
