Ciscoworks with Veritas Backup Exec
forumhealth
Are there any known issues or restrictions on using Backup Exec to back up a server running Ciscoworks LMS3.1? For example, are there any databases or directories which need to be excluded from the backup job? We are using the Ciscoworks backup utility, but want to back up the entire server to tape.
Joe Clarke
Sounds like you have things under control. Make sure you backup the LMS backups as well.
You should exclude NMSROOT\databases from your Backup Exec job.
Thanks, Joe. It looks like we're good to go.
Cheers,
Al
