Clear Crypto Gdoi
russell.turner
Need to a little help debugging  a EEM applet. The scripts hangs at line 1.0. I try to research to see if that was right syntax. The command prompts for yes or no but that is where is hangs and then timesout. See original script.
Try:
event manager applet ... authorization bypass
And see if that works for you.
Joe Clarke
The applet looks okay.  Do you have any AAA command authorization configured on this device?  What version of IOS is this?
Thank J. Clarke for replying so quickly.  Yes I do have AAA configured. I am running IOS Version 15.1(4)M4,
Try:
    That works Joe much thanks.
  Actv success  Thu Oct 4 18:44:29 2012  syslog             applet: GDOI_KEYSEVER_RESET
