CLI Output to Local SNMP oid value
etamminga
I've written a simple TCL script that executes some IOS statements to figure out a certain network state.
I'd like this state to be readable via SNMP.
Can someone tell me how to store a value in the local IOS snmp manager so it can be read by any SNMP capable agent?
Should I be looking at RFC2982 / DISMAN-EXPRESSION-MIB to store my values? Or is there any other location in the SNMP MIB I can use to store custom values?
Erik Tamminga
Here you go:
https://supportforums.cisco.com/document/77026/cli-value-2-snmp-expr-mib
Joe Clarke
The EXPRESSION-MIB is the way to do it reliably.  There is an example EEM Tcl policy in this forum under the Documents tab that shows how to do this.
Can you please point me to the document that shows me how? A simple search on Expression-mib in this documents section doesn't give me results.
Erik
Here you go:
