10-30-2007 02:01 AM
We have a problem when we click on the Trunk VLANs Mismatch in the Discrepancy Report.
The message appear:
<<Error while loading. Campus Manager Server may be down.>>
We check the status but CM is up and running.
Thanks for any help or hints
10-30-2007 06:44 AM
It could it be maybe and just maybe a bug in tehe internet explorer version, did you try to change the IE version to an older one?
11-05-2007 11:28 AM
IE6 also didn't work.
10-30-2007 08:37 AM
By, "CM is up and running," I assume you mean the ANIServer process is working? If so, check the Campus.log for any errors.
11-05-2007 11:27 AM
No errors in the Campus.log. ANIServer process is running. Any other ideas?
11-05-2007 12:15 PM
Check the NMSROOT/MDC/tomcat/logs/stdout.log. That should have some error relating to what you see in the GUI.
11-08-2007 12:09 AM
11-08-2007 10:30 AM
Looks like a problem with your license or your LicenseServer process. Check to make sure the LicenseServer process is running, and see if there are any other errors in license.log.
11-09-2007 07:22 AM
11-09-2007 08:08 AM
Shutdown LicenseServer, then check to see if anything is listening on TCP port 40401. If you use netstat -a -n -o -b, you can see the process that is listening on this port (if any). If you find one, kill the process, then restart LicenseServer.
