CM Network topology map
baotran09
Is it possible to create an ACS account to permit end users to view only Campus Manager network topology map?
Joe Clarke
Yes, but only in LMS 3.2.  You must first set the following property to true in NMSROOT/campus/etc/cwsi/ANIServer.properties:
Topo.ACSAuthorizedView=true
Thanks Joe.
Are there any doco on how to create an end user account on ACS which will allow the user to access ciscoworks to view only the topology map?
Besides the LMS user guide, this white paper talks about how to enable ACS integration:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/prod_white_paper0900aecd80613f62.html
It's a bit old, but the ACS configuration steps are still the same.
