CM - Topology Filter "PoE Devices" is not showing the correct devices.
jmartinsen
Beginner
Beginner
What is the criteria for devices to be highlighted when you select the Topology Filter "PoE Devices" in the Network topology view in CM ?
Is it on device type or does the device need to respond on MIB queries on the POWER-ETHERNET-MIB ?
I have devices that don't have PoE, but they are highlight when I select the Topology Filter "PoE Devices" and I also have an 3560 that doesn't get highlighted (and it has PoE).
If I try to configure PoE on the 3560 from CiscoView, CiscoView has no problem with seeing it as an PoE Devices.
Can someone tell me how the Topology Filter "PoE Devices" are selecting devices ?
Best regards
John
ebreniz
Frequent Contributor
3560 PoE devices are appearing in Topology Services when the filter for PoE Capable Devices is enabled. POE Devices heading in topo filter can be changed to PoE Devices
The following link will help you
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_campus_manager/5.0/user/guide/topo.html#wp1043413
Joe Clarke
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
The PoE filter is based on device type. The list of types are stored in NMSROOT/campus/main/filters/POECapableDeviceTypes.properties. These types correspond to the label type you see in Campus Manager.
the customer has the same problem:-( He doesn't see the 2960 PoE with filter enabled in the topology view:-( I cann't to find your file:
In the campus folder are following folders: bin, etc, lib and www.
Thank you
Roman
Joe Clarke
Please start a new thread for your issue.
Recognize Your Peers
