05-28-2014 02:22 AM
I have a WS-C2960X-24TS-LL and i want to add this product to CNA 5.8.9.1 :
Using Discover like a single device by IP address and device IP, the CNA detect perfectely the new switch and sends this error on first connection:
Error Connect : Index 26, Size 26
Log : Application_Log_Wed_May_28_11_18_45_CEST_2014-1401268725817.txt
How to proceed?
Thank you
07-12-2014 02:23 PM
CNA 6.0 and WS-C2960X-24TS-LL have same error index 26 size 26 :(((
09-23-2014 11:47 PM
hello i have the same error when i try to open Smartports with CNA 6.0
is there a fix for this problem ???
------------------------------------------Application-Log---------------------
Http Status Code : 200
java.lang.IndexOutOfBoundsException: Index: 26, Size: 26
at java.util.ArrayList.RangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at com.cisco.cpnm.legacy.networkdata.CommonSlot.getPort(CommonSlot.java:115)
at com.cisco.cpnm.legacy.frontpanel.ui.WS_C2960X_24TS_S_SwitchPaint.<init>(WS_C2960X_24TS_S_SwitchPaint.java:84)
at com.cisco.cpnm.legacy.networkdata.WS_C2960X_24TS_S_Switch.getFrontPanelPaint(WS_C2960X_24TS_S_Switch.java:146)
at com.cisco.cpnm.frmwrk.net.frontpanel.FrontPanels.setPopupDevices(FrontPanels.java:620)
at com.cisco.cpnm.frmwrk.net.wd.WDFrontPanelSelector.setDevices(WDFrontPanelSelector.java:149)
at com.cisco.cpnm.features.defn.smartports.SmartPortsPortSetupTask.updateMirrorFromDevice(SmartPortsPortSetupTask.java:217)
at com.cisco.cpnm.frmwrk.gen.wd.WDComponent.updateMirrorFromDevice(WDComponent.java:540)
at com.cisco.cpnm.frmwrk.gen.wd.WDContainer.updateMirrorFromDevice(WDContainer.java:597)
at com.cisco.cpnm.frmwrk.gen.wd.WDTabbedPane.updateMirrorFromDevice(WDTabbedPane.java:988)
at com.cisco.cpnm.frmwrk.gen.wd.WDWidget$2.run(WDWidget.java:1193)
at java.lang.Thread.run(Unknown Source)
++: DEBUG: : *** UAT Recorded: timestamp=1411541017524, source=feature_updateMirrorFromDevice, feature=Smartports, desc=, startT=1411541016466, endT=1411541017524, duration=1058
