CNA question: enabled http is a must?
t.goldpergel
I have a simple question: Enabled HTTP is a must for connect Cisco Network Assistant to a switch (for example Cat3560v2) or https access is enough?
thx in advance!
bllang
HTTPS was a little bit broken in 5.7. We have fixed it in 5.7.6 and it will be released in the next day or so.
Thanks and thanks for using CNA!
5 Replies 5
Hi Tivadar,
IP HTTP server or HTTPS server needs to be enabled in order to allow the CNA to access the device. There are some more options you can configure.
Have a look here (it is for the 4500 series):
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/quick/guide/English/C4K_GSG.html
I hope that helps :-)
Dear Nathanael,
http server _OR_ https server needs to be enabeled?
My experince was if only https (and not hte http) was enabled network assistant didn't work.
Your issue seems similar to :
https://supportforums.cisco.com/message/3613261#3613261
it may be a broken HTTPS if you have CNA 5.7.x. You may open a TAC case to check further.
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
bllang
Thanks William!
Https works with ver 5.7.6
Unfortunately 5.7.5 was using when we upgraded our switches to https capable.
Kind regards,
Tivadar
