I am using the CNR release 6.0.5.2 nightly build# 41524, GUI obj: 250. I am trying to use the GUI to set option-122( CCC) but, find no reference to it at all in the GUI. I tried custom option too but, it does not allow me to input option 122.
On the other hand in the CLI version that came along with it I find the option listed. But, I am finding it difficult to set-up all the sub-options using it. Hence, wanted to know if it is supported in the GUI version if so which version and if so how to set the DHCP otpion 122.
