cnr login trouble
Issarapong
# ./nrcmd
username: root
password: changeme
401 Login Failure - cluster localhost: no nrcmd permissions
any help please?
Network Registrar - Local
Release 7.2
Solaris build #7.2.1104272106
austin.platt
I get the same. Help!
I cleared by chang password login CNR (GUI) to Default password .Password is "changeme" you can try
Yep, that did it. Many thanks.
