LMS 4.2 monitoring capability
dionjiles
Does this version supports multi-vendor support other than Cisco.
We have Brocades Load Balancers/switches, Junipers Firewalls, and Fortinet devices on our network and we are interested to see if Ciscoworks supports any of these device platforms.
Michel Hegeraat
Level 7
Level 7
Right now, out of the box, LMS can check the availability of these non-cisco devices.
You can also monitor the interfaces of the devices. traffic errrors etc. For this you have to create a poller and specify what interfaces it should monitor.
If you import mibs you can select numeric OID's to watch.
Cheers,
Michel
Thanks for the quick response.....this is what I needed.
