Command "netconf-yang" doesn't open port 830
RAW1456
Greetings,
I am using a Cisco ISR4321 running IOSXE 16.06.04
I am trying to get started with NETCONF and according to every tutorial I've read the command "netconf-yang" should be enough to start the NETCONF service and open Port 830, however, trying to get the Router's capabilities via
ssh -s <user>@192.168.88.211 -p 830 netconf
returns
ssh: connect to host 192.168.88.211 port 830: Connection refused
An NMAP scan also doesn't list Port 830 as open.
The service is definitely running though:
Router#show platform software yang-management process
confd            : Running
nesd             : Running
syncfd           : Running
ncsshd           : Running
dmiauthd         : Running
vtyserverutild   : Running
opdatamgrd       : Running
nginx            : Running
ndbmand          : Running
I've been stuck on this for a while now and would greatly appreciate any hints as to what I'm missing here.
Mark Elsen
 - Check if this guide can help you :
           https://www.cisco.com/c/en/us/support/docs/storage-networking/management/200933-YANG-NETCONF-Configuration-Validation.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you, but that seems to be the exact guide I've been using.
As I understand it, it states that if AAA and Syslog/SNMP monitoring aren't required you only need the basic SSH configuration and the "netconf-yang" command for the aforementioned Capabilities check to work.
For troubleshooting it only states that if the test doesn't work, there may be a firewall blocking Port 830 but I've already tested the command while connected directly to the router.
My answer comes late, but may help the ones who fall on this page.
I recently got the very same behaviour after deleting some crypto keys (i know it is bad :))
To restore them, you can disable and reenable netconf like :
csr-hub(config)#no netconf-yang
csr-hub(config)#
*Jun  9 15:01:04.021: yang-infra: netconf-yang server has been notified to stop
csr-hub(config)#
csr-hub(config)#netconf-yang
The existing self-signed trustpoint cannot be used for NETCONF.
Delete it and create a new one? [yes/no]: yes
CRYPTO_PKI: setting trustpoint policy TP-self-signed-3222202584 to use keypair TP-self-signed-3222202584
csr-hub(config)#
My reply may come late to this as well, but THIS finally pointed me in the right direction. After reenabling netconf-yang, a log message notified me that it was using an old trustpoint certificate. I disabled netconf-yang, deleted the cert, and reenabled netconf-yang. I then tested SSH over port 830 from Prime, and it finally let me accept the certificate in Prime.
