Command way to enable/disable ACL switch SG350-28p
Alzor
Hi threre !
First of all thanks for reading it =). I have a ACL created via web interface, and I need to apply it to a determinate port by command.
I have been surfing in the community and I every where say the same:
Device> enable
Device# configure terminal
Device(config)# interface fastethernet 0/0/0
Device(config-if)# ip access-group <created_ACL> in
Device(config-if)# end
The problem is that the command "ip access-group" is not recognized in my cisco. If I put the "?" command to see the posibles commands only appear "ip access-list".
What I am doing wrong? Any idea?
Thanks again.
luis_cordova
Hi  @Alzor ,
Query, the ip access-list command achieve to apply the ACL?
Sometimes you will find different ways to apply an ACL, could be access-list, access-group, access-class.
But all should achieve the same.
Try the command that you mention and tell us how it goes with that
when I try to use this command, the param that must be putted are ones to create a new ACL. If I do it an error happend because the name of the ACL is repeated each time I executed the command.
So, by this way I cant automatized the process.
PD: thanks for the reply.
