Commands disappeared from the 2950 series as nexus
jbseong
2950_A(config)#no service tcp-small-servers
2950_A(config)#no service udp-small-servers
2950_A(config)#no service finger
2950_A(config)#no service pad
2950_A(config)#no ip source-route
2950_A(config)#no ip bootp server
2950_A(config)#no ip domain-lookup
2950_A(config)#no ip http server
2950_A(config-if)#no ip redirects
2950_A(config-if)#no ip unreachables
2950_A(config-if)#no ip directed-broadcast
2950_A(config-if)#no ip proxy-arp
2950_A(config-if)#no ip mask-relay
With Nexus we changed the switch. I tried to put the same command as above, but I couldn't.
What is the correct command for Nexus in the above item?
marce1000
 - Some of these commands may simply not be available in nx-os ; have a look at this document concerning hardening nx-os devices :
                               https://tools.cisco.com/security/center/resources/securing_nx_os.html
 M.
This is not what I want.
It is possible, impossible, this is enough.
For each item.
I can't see it if I look for it over there.
I want to know that it is possible and impossible, and if possible, I want to know the appropriate command.
I'm not asking you to find documents or web pages.
