Hello All!
I've just installed the application and I'm getting a lot of trouble trying to add a device either manually or via automatic discovery to my monitored devices...
Whenever I try to add a device with automatic discovery, I add the credentials (for a CUCM 7) and then go to schedule, select the IP for seed device and then run the discovery... I see an error that goes like:
An exception occurred while scheduling a discovery. Make sure System Identity user is configured with full privilege.
or
Please make sure that a schedule is specified and that the jrm process is running properly. If this problem persists, please restart jrm process by executing the following commands,
pdterm jrm
pdexec jrm
Then, I tried to go and Add the Device using the same credentials and got an error like:
Cannot add device.
See the
NMSROOT/.../TIS/DeviceManagement.log
file for more information.
I'm attaching this file so you can take a look...
I've restarted services (and even the server) tried to reinstall application but couldn't make it work... Have anyone seen anything like this? Is there something obvious I'm missing? This is the first time I mess around with an NMS product, I'm more related to Voice products, so I'm totally lost here...
Greetings...
Josemo
