06-21-2011 02:23 AM
I use the Edit Identity option to change the "Display Name" from an IP to a station name, it is overwritten when a discovery has been done. I have checked the discovery settings and tried using the update DCR Display name setting to prevent this from happening, but it makes no difference.
Is there something i am missing? This is on LMS 3.2
06-21-2011 02:46 AM
Hi ,
In LMS 3.2 there is one more discover settings called Scheduled Discovery .
Common service > Device and Credentials >Device Discovery >Discovery Schedule.
Please check the settings there and see if there is a problem.
For more information on Common Service >Discovery , you can always refer this document written by Joseph Clarke sir :
https://supportforums.cisco.com/docs/DOC-9005
Afroj
06-22-2011 12:22 AM
Hi Afroj,
I have tried with this tick box unnticked and it has no effect.
It still overwrites the display name. Is there perhaps a fix for this?
