Voice Gateway DFM Notifications
BlueyVIII
We have a 2800 route which is configured as a Voice Gateway.
For some reason, yesterday we started getting DFM notifications like the one below.
Any idea's what the means? We seems to get an active messages every few 10mins or so, then a few minutes later the message will clear before becoming active again...
EVENT ID                = 0009NK2
ALERT ID                = 0000QTM
TIME                    = Tue 21-Jun-2011 16:06:50 BST
STATUS                  = Active
SEVERITY                = Critical
MANAGED OBJECT          = XXXXVG1
MANAGED OBJECT TYPE     = Routers
EVENT DESCRIPTION       = OperationallyDown::Component=IF-XXXXVG1/39 [FXO NULL 0/0/0:15];ComponentClass=Interface;ComponentEventCode=1075;Type=VOICEFXO;IsFlapping=false;AdminStatus=UP;MaxSpeed=0;OperStatus=DOWN;InterfaceCode=CODEUNKNOWN;Mode=NORMAL;DuplexMode=FULLDUPLEX;La
Will Pettit
We started getting the exact same thing yesterday as well. Can you confirm what IOS version you're running. We're on c2800nm-ipvoicek9-mz.124-15.T5.bin. We've got 2 x E1 cards installed and are getting on both:
EVENT DESCRIPTION       = OperationallyDown::Component=IF-XXXXXGW1/102 [FXO NULL 0/1/0:15];ComponentClass=Interface;ComponentEventCode=1075;Type=VOICEFXO;IsFlapping=false;AdminStatus=UP;MaxSpeed=0;OperStatus=DOWN;InterfaceCode=CODEUNKNOWN;Mode=NORMAL;DuplexMode=FULLDUPLEX;L
EVENT DESCRIPTION       = OperationallyDown::Component=IF-XXXXXGW1/39 [FXO NULL 0/0/0:15];ComponentClass=Interface;ComponentEventCode=1075;Type=VOICEFXO;IsFlapping=false;AdminStatus=UP;MaxSpeed=0;OperStatus=DOWN;InterfaceCode=CODEUNKNOWN;Mode=NORMAL;DuplexMode=FULLDUPLEX;La
EDIT:
These alerts suddenly stopped at approx 3AM GMT today. Out of interest which Telco do you use? We're using Cable & Wireless.
