08-08-2005 03:35 PM
Can somebody tell me if I am doing this correcctly. The RME Compliaance check is saying the device is compliant and I don't think it should. I have a baseline config with the line "+ service password-encryption", and a 3750 that has the line "no service password-encryption". The compliance job says that "1 of 1" devices are compliant. I have also tried checking the box that says "check and deploy".
08-12-2005 12:16 PM
With the RME Baseline template and compliance check you can execute this functionality:
First identify a set of standardized policy-based commands that you want to have on a set of devices.
Then create Baseline templates with those set of commands identified. After creating the baseline
templates, you can accomplish following tasks.
Compare device configurations and generate a report that lists all the devices that are non-compliant
to the baseline template.
Deploy the baseline template to the same category of devices in the network.
Schedule a compliance check job and deploy the baseline template on to the devices.
http://www.cisco.com/application/pdf/en/us/guest/products/ps2425/c1244/cdccont_0900aecd8026ee8d.pdf
08-22-2005 03:18 PM
I followed these steps. From what I can tell there is a problem with the compliance check. I was able to do config distribution as merges and overwrites. Does anyone have the compliance check working with this version?
