conf reg
aksher
what are possibilities in setting up conf reg
0*2102-loads IOS from flash
0*.......
pkhatri
Level 11
Level 11
Here's a link that describes the various options:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/cis2500/2505/2500him/77108.htm
Hope that helps - pls do rate the post if it does.
Paresh
desai.jaideep
Level 5
Level 5
Apart from the documentation, download this cool tool from Boson.It is conf reg generator.
http://bosondownload.com/utils/bos_sub.exe
Pls rate all posts.
JD
