Config GNS3 VM inside a Win10 Virtual machine
I need to create a GNS3 lab for internet access via the router inside a Win10 VM. For that, I used a NAT cloud, and that was okay. However, with NAT, I could not access the router's IP from the hosted laptop. Therefore, I tried to use the cloud. However, all the articles about configurations are using the GNS3 VM with that.
  1. Is there any other method to use the cloud function to access the internet as well as access the router from the host, without using the GNS3 VM?
  2. When I try to add the GNS3 VM inside the Win10 VM, it shows an error related to virtualization being enabled in the Win10 VM. I tried enabling the VM settings option, but the issue remained the same. Is there any method to enable virtualization for the GNS3 VM, which needs to be run inside the Win10 VM?
Thank you
balaji.bandi
Hope you aware that this is cisco community - not GNS3 , may be posting with GNS community get more reply than here.
https://www.gns3.com/community/featured
BB
Ahh sorry. i will do that.
Thank you
