Config Network Flow (Monitor/Record/Export)
eeebbunee
Level 3
Level 3
Hello Professionals,
I would like to config netflow to see ip top talkers from the specific interface traffics, but I couldn't finish my configuration because of the config error. Can you see my config and correct me?
ERROR>> when I apply flow monitor to interface gi1/0/3, it gives me:
Probably I forgot something to config 'ip flow monitor', but I couldn't find..
Here is my config >>
  -Exporter Destination : switch itself. (C9300L, ver:16.12.4)
I don't understand the roles of Monitor/Record/Exporter respectively, I would much appreciate if someone explain that.
Thank you very much.
 Add to you record, this command:
flow record LOCAL_MPLS_RECORD
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match interface output
collect routing source as
collect routing destination as
collect routing next-hop address ipv4
collect transport tcp flags
collect counter bytes
collect counter packets
collect timestamp sys-uptime first
collect timestamp sys-uptime last
eeebbunee
Level 3
Level 3
Thank you for the response Flavio Miranda,
I resolved this issue by creating two flow monitors, and two flow records (In / Out).
Thank you!
