Configuration Management in LMS 4.1 is not working
I need to archive the configuration for the devices but it states that SSH fails to authenticate although I have checked the credentials many times.
stephen.stack
Level 4
Level 4
Can you send a screenshot of the error? Or any LMS logs that can assit with troubleshooting? Are you able to ssh direct from the LMS server?
Stephen
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
- Always vote on an answer if you found it helpful
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
