Configuration
1291047
Community Member
I am doing a lab and I want to know why in the Rprueba router when I try to log in I can only see the password but I can not write the user, I attach the configuration of the routers.
CONFIGURATION OF RMEDIA
hostname RMEDIA
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
no ip cef
no ipv6 cef
redundancy
ip tcp synwait-time 5
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
ip address 10.37.10.101 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex full
speed 1000
media-type gbic
negotiation auto
interface GigabitEthernet1/0
no ip address
negotiation auto
interface GigabitEthernet1/0.1
encapsulation dot1Q 501
ip address 10.88.1.1 255.255.255.0
ip nat inside
interface GigabitEthernet1/0.2
encapsulation dot1Q 778
ip address 10.91.2.1 255.255.255.0
interface GigabitEthernet1/0.3
encapsulation dot1Q 790
ip address 10.92.3.1 255.255.255.0
interface GigabitEthernet1/0.4
encapsulation dot1Q 800
ip address 10.93.4.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface GigabitEthernet2/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet3/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list NO_NAT interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.37.10.1
ip route 10.88.1.0 255.255.255.0 10.88.1.145
ip route 10.90.98.0 255.255.255.0 10.91.2.146
ip route 10.90.99.0 255.255.255.0 10.92.3.147
ip route 10.90.100.0 255.255.255.0 10.93.4.148
ip route 192.168.20.0 255.255.255.0 10.91.2.146
ip access-list extended NO_NAT
permit ip 10.37.10.0 0.0.0.255 10.88.1.0 0.0.0.255
access-list 1 permit 10.88.1.0 0.0.0.255
access-list 101 permit tcp any host 10.37.10.9 eq tacacs
no cdp log mismatch duplex
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input none
end
CONFIGURATION OF RBACKUP
hostname RBACKUP
boot-start-marker
boot-end-marker
logging buffered 9000
enable secret 9 $9$TojNA.HR9KgNuU$Ys2r9H3zrJgVt7UloEuQeKDXalGtW3abjWCcLeTIIdk
aaa new-model
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default
action-type start-stop
group tacacs+
aaa accounting commands 1 default
group tacacs+
aaa accounting commands 15 default
group tacacs+
aaa accounting network default
group tacacs+
aaa accounting connection default
group tacacs+
aaa session-id common
clock timezone GMT -5 0
ip vrf RPV_1
rd 1:1
route-target export 1:1
route-target import 1:1
ip vrf RPV_2
rd 2:2
route-target export 2:2
route-target import 2:2
ip dhcp pool LAN_POOL
network 192.168.55.0 255.255.255.0
default-router 192.168.55.1
dns-server 8.8.8.8 1.1.1.1
lease 7
no ip domain lookup
ip name-server 200.62.191.11
ip name-server 200.24.191.11
ip name-server 200.62.191.12
ip name-server 200.24.191.12
ip cef
login on-success log
no ipv6 cef
redundancy
no ip address
shutdown
duplex auto
description Interface WAN BEMBOS SAC - SEDE CENTRAL CERRO COLORADO
no ip address
duplex full
speed 1000
media-type gbic
negotiation auto
interface GigabitEthernet0/0.1
ip address 10.88.1.145 255.255.255.0
interface GigabitEthernet0/0.2
ip vrf forwarding RPV_1
ip address 10.91.2.146 255.255.255.0
ip nat outside
description RED_LAN
ip address 192.168.55.1 255.255.255.0
shutdown
negotiation auto
ip address 192.168.20.1 255.255.255.0
ip nat inside
negotiation auto
ip vrf forwarding RPV_2
ip address 192.168.30.1 255.255.255.0
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router eigrp 100
address-family ipv4 vrf RPV_1 autonomous-system 1
network 192.168.20.0
exit-address-family
no ip http server
ip nat inside source list 1 interface GigabitEthernet0/0.2 overload
ip route 0.0.0.0 0.0.0.0 10.37.10.101
ip route 0.0.0.0 0.0.0.0 10.88.1.1
ip route vrf RPV_1 0.0.0.0 0.0.0.0 10.37.10.101
ip route vrf RPV_1 0.0.0.0 0.0.0.0 10.91.2.1
ip route vrf RPV_1 10.37.10.9 255.255.255.255 10.91.2.1
access-list 1 permit 10.91.2.0 0.0.0.255
access-list 1 permit 0.0.0.0 255.255.255.0
tacacs-server host 10.37.10.9
tacacs-server key CLARO&blitz
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
transport input all
end
CONFIGURATION OF Rprueba
hostname rRPV_BEMBOS_REALPLAZA
boot-start-marker
boot-end-marker
logging buffered 10000 informational
enable secret 9 $9$ajoqXaULehAfCk$W1WEKHn.lCDsrckiB13ge1jUSMc7LKgVwFFopp8b/O.
aaa new-model
aaa authorization exec default group tacacs+ none
group tacacs+
group tacacs+
group tacacs+
group tacacs+
group tacacs+
clock timezone UTC -5 0
ip vrf RPV_1
rd 1:1
ip dhcp excluded-address 192.168.22.10
network 192.168.22.0 255.255.255.0
default-router 192.168.22.1
dns-server 8.8.8.8 8.8.4.4
lease 7
no ip domain lookup
ip domain name ejemplo.com
ip cef
no ipv6 cef
redundancy
ip ssh version 2
class-map match-any qos2
match ip dscp cs2
policy-map wan
class qos2
bandwidth 2560
police 2560000 480000 960000 conform-action transmit exceed-action set-dscp-transmit cs1
interface Loopback0
no ip address
shutdown
interface Loopback1
ip address 10.37.10.2 255.255.255.255
interface Loopback30
ip address 10.99.165.208 255.255.255.0
no ip address
shutdown
duplex auto
description WAN RPV - CID 21746992 BEMBOS SAC - SEDE REAL PLAZA AREQUIPA
ip address 192.168.20.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
duplex full
speed 1000
media-type gbic
negotiation auto
description RED_LAN
ip address 192.168.22.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
router eigrp 100
distribute-list route-map FILTRO_EIGRP out
exit-address-family
no ip http server
ip route vrf RPV_1 0.0.0.0 0.0.0.0 10.91.2.146
ip route vrf RPV_1 10.37.10.9 255.255.255.255 192.168.20.1
ip prefix-list REDES_EIGRP seq 5 permit 192.168.22.0/24
ip prefix-list REDES_EIGRP seq 10 permit 192.168.20.0/24
ip prefix-list REDES_EIGRP seq 15 permit 10.37.10.0/24
access-list 101 permit tcp host 192.168.20.2 host 10.37.10.9 eq tacacs
route-map FILTRO_EIGRP permit 10
match ip address prefix-list REDES_EIGRP
snmp-server community mra RO
snmp-server trap-source Loopback30
snmp-server enable traps entity-sensor threshold
snmp-server host 192.168.57.98 version 2c mra
tacacs-server host 10.37.10.9 key CLARO&blitz
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
transport input ssh
end
which from the router Rprueba I can enter with ssh to the tacacs server, but when I want to enter with ssh to this same router to corroborate that it is well and that the tacacs server is authorizing and authenticating, I always have to put the local password but not the password that is in the tacacs server.
@1291047
Probably the router is not communicating with tacacs server.
As per the tacacs server IP address, the router should send the traffic through interface loopback1,which is using VRF.
ip tacacs source-interface loopback1 vrf RPV_1
