configure ip flow destinatio to a DNS record
yoav-shneor
Hi ,
Is it possible to configure ip flow destination to a DNS record ?
insted of writing an ip address , to insert a name like "myflow.customer.org" .
Is it possible ?
do i need to config resolving ? or local host for that ?
Mark Elsen
 - Put a ? at the end of the designated command, you will see what the possible options are for the host name , probably it can be a DNS name , which must then be resolvable at the time the command is being entered BUT what happens is that the translated address is burned into the running config , meaning that the 'DNS gaming' can not be used for failover purposes,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
TNX Bro ,
