configuring for SNMP V3 on cisco switches C3560
WIN PHYO AUNG
We are currently using SNMP as below config.
What is the current SNMP version enable. I understand that if no "version" command, default is version1. Is it?
And we are planning to migrate to V3.
What need to be configured on our switches to work with version?
What information should i check with our monitoring server team?
Can we configure to add in without affecting existing monitoring ?
Existing
snmp-server community STRING RO
snmp-server trap-source Vlan150
snmp-server source-interface informs Vlan150
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps power-ethernet group 1
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps config-copy
snmp-server enable traps hsrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistenc        y
snmp-server enable traps syslog
snmp-server enable traps rtr
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host x.x.x.x STRING
AFROJ AHMAD
Hi ,
Ans: currently , you are using SNMPv2c .
snmp-server host x.x.x.x STRING  >> If you don't specify anything in this command then only SNMP v1 traps will be sent. In this same command you can specify the type of traps you want to recive.
for e.g:
WL-6500(config)#snmp-server host 11.1.1.1 version ?
  1   Use SNMPv1
  2c  Use SNMPv2c
  3   Use SNMPv3
Attached is the SAMPLE SNMPV3 configuration :
you need to add the device or eidt the device with SNMPV3 credentials on the monitoring tool.
Yes.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
6 Replies 6
AFROJ AHMAD
Hi ,
for e.g:
  1   Use SNMPv1
  2c  Use SNMPv2c
  3   Use SNMPv3
Yes.
Thanks-
Afroz
Hi Afroz,
Thanks for the sharing.
I think in the attach steps, you are using local user account, is it? For remote users, we need to define remote Engine ID?
I am confused with view, is "iso" the standard MIB view?
Win
Hi ,
I think in the attach steps, you are using local user account, is it?  Yes
For remote users, we need to define remote Engine ID? Yes , you are correct.
I am confused with view, is "iso" the standard MIB view?  yes ISO is the TOP in the hierarchy of the MIBS
Thanks-
Afroz
Afroz,
Thank you for the replay. It really helped.
Win
that's  great..
Kindly resolved the thread \ rate the post
Thanks-
CiscOptimist
You can find a step-by-step guide on how to configure SNMP v3 on any Cisco device, including IOS based ones like C3560:
https://bestmonitoringtools.com/configure-snmpv3-on-cisco-router-switch-asa-nexus-a-step-by-step-guide/
