Configuring IP Phones to a Router that is already Configured
trenaschulze
I have a router that is connected to a switch and the switch then has two IP phones. I already configured my router with a default gateway and OSPF routing. When I go to configure my IP phones on the router, it is saying that my default gateway (the gateway of my my router) is conflicting. How do I connect my two IP phones and assign them phone numbers so that they can call each one, when my router is already configured? Thank you for the help!
3 Accepted Solutions
@trenaschulze
 Your DHCP pool on the router is not correct.
If you are using the gateway as 192.168.100.161 and mask 255.255.255.224, the network must be 192.168.100.160
ip dhcp pool VOICE-POOL
network 192.168.100.160 255.255.255.224
default-router 192.168.100.161
option 150 ip 192.168.100.161
You need to use voice vlan on the switch and you need to setup the call manager on the router if you want to play with the phone
PacketTracer have some tricks. You need to use the router 2811 if you want to play with phone,  It is the only router that have  telephony-service Configure Cisco Unified Communications Manager Express
Once you replace the router for the appropriate model, you can use below script to create the station.
This will create the station 7890 and 7891, change it to anything you want.
telephony-service
no auto-reg-ephone
max-ephones 6
max-dn 6
ip source-address <router IP> port 2000
ephone-dn 1
number 7890
ephone-dn 2
number 7891
ephone 1
device-security-mode none
mac-address <phone mac address>
type 7960
button 1:1
ephone 2
type 7960
button 1:2
One more tip, use vlan 1 for voice vlan.
That´s correct.  Using the model I told you, you will be fine
5 Replies 5
@trenaschulze
Thank you!  Yes I'm using the 192.168.100.161 and mask 255.255.255.224 as my gateway. The network is 192.168.100.160
I already created the voice vlan on the switch. When I go to the router, I have not enabled a ip dhcp pool for voice. I will try that.
telephony-service
no auto-reg-ephone
max-ephones 6
max-dn 6
ephone-dn 1
number 7890
ephone-dn 2
number 7891
ephone 1
type 7960
button 1:1
ephone 2
type 7960
button 1:2
Thank you! I realized that my router was wrong, because when I went to enable telephony, it wasn't listed as an option. Thanks for your help!
