DHCP - Default Gateway not populating on PCs
trenaschulze
In the LAN 1 - I have 1 DHCP server, 3 PCs, 2 switches, and 2 routers. One of the routers interface is the gateway. I already assigned the gateway port on the router. I assigned the DHCP server an IP address, and then did the server pool to automatically assign the 3 PCs. When I turn on DHCP on the PCs, everything populates except the gateway IP address. If I assign it static, it will ping, and connect. Does anyone know why it won't assign the gateway? I added the gateway address in my pool. Thanks for your help.
2 Accepted Solutions
Blue_Bird
Hello trenaschulze,
In DHCP server(192.168.100.3) settings, LAN1 pool is overlapping with ServerPool(default)
Remove the LAN1 Pool and Edit the Server Pool with required settings and save it works..!!
or keep LAN1 pool, and clear (delete) server pool settings (default gateway and dns info) and save then also it works..!
Best regards
******* If This Helps, Please Rate *******
trenaschulze
Thank you! That worked!
Blue_Bird
Hello trenaschulze,
Best regards
trenaschulze
