Configuring IPM 4.1
akash04lingam
     When i am configuring IPM 4.1 for udp jitter operation. i am getting the error message as "Only responder enabled devices permitted for selected operations" , but i have configured the "ip sla monitor responder" command both in source and target devices. I have attached the screen shot of the error message also. Please explain me how to overcome the problem.
Joe Clarke
You need to make sure your target device is seen as a responder-enabled device by IPM.  If you enabled the responder after adding the device to IPM, delete the device from IPM, and add it again.
