Configuring NTP on Cisco Prime Infrastructure 3.1.7
Eric R. Jones
Level 4
Level 4
I have configured the ntp settings on our Prime Infrastructure 3.1.7 maintenance release 7.0.0 prime pack 16 on a second gen appliance.
I can ping and traceroute to the IP address that is feeding NTP data to all our devices; however Prime is not getting synchronization from the time server. The refid is on .INIT. with a stratum of 16.
I tried a reload but nothing new.
The options for configuring NTP on Prime are extremely limited for showing data.
ej
RichardAtkin
Level 3
Level 3
Might be better if you put this in a Prime area as opposed to an ISE area.
That said, I have noticed NTP is sometimes slow to sync - wait a good while (like, hours) and check again?
oops, sorry I thought I had the correct location. Ok, I'm willing to wait bit.
I was trying to find a debug command to run
ej
