07-12-2014 09:17 AM
Hello there,
So here is my situation. I have 20 2960 CG to configure and since I changed my computer to the Dell 7440 it is a nightmare.
This laptop does not have a serial so I am using a star-tech adapter with the Windows Driver PL2303.zip
Everything runs fine for about a minute or 2 (when lucky ) and then I loose the connection.
That said, the only way to get the connection back is too reboot the computer.
I contacted Dell and one tech came over to check the computer and everything is fine.
We reformatted the machine, reinstalled Windows 7x64, updated everything and still the same.
I also tried through putty and other hyperterminals and still the same.
I am kind of lost.
(I also do not wish to wish to purely usb to micro usb as next week I ll have another batch of switch that do not have the usb console).
Any help will be greatly appreciated !!
Thanks.
07-12-2014 11:58 AM
One of this thread has same issue. Just try the recommendations there and see anything turns out to be helpful.
-Thanks
Vinod
07-12-2014 05:17 PM
Thanks, I ll try.
But my issue appears also with Hyperterminal so for sure it is not related to Putty.
I will keep you posted after testing.
07-14-2014 06:36 PM
I got saved by Tera Term 🙂
Still strange though.
