Control Plane Policy
glsparks
I have an issue with a control plane policy that is tearing down BGP without any specific pattern.
ip access-list ex TEST
permit tcp host 192.168.1.1 host 192.168.1.2 eq bgp
permit tcp host 192.168.1.1 eq bgp host 192.168.1.2
policy-map CONTROL_PLANE_POLICY
class COPP_ROUTING
police rate 500 pps burst 750 packets peak-rate 1000 pps
conform-action transmit
exceed-action transmit
violate-action drop
class class-default
police rate 10 pps
conform action drop
So after a period of time BGP gets torn down. The peer is only sending a default route. The policy map does not show any exceed or violate in the COPP_ROUTING class.
What would be causing this?
Did you check arp  it can Control plane drop arp which need for bgp to establish tcp connections
MHM
MHM
Yep that did it. Created:
class-map ARP
match protocol arp
stuck that in the policy-map CONTROL_PLANE_POLICY
BGP has stayed up!
Ramblin Tech
class class-default
  police rate 10 pps
  conform action drop
What is the intended purpose of policing to 10pps and dropping packets that conform to this rate? Note: I am more familiar with XR's LPTS than IOS's COPP.
Disclaimer: I am long in CSCO
A very good spot. Just me typing it in for the sake of brevity i'm afraid.
It actually reads
class class-default
police rate 10 pps
exceed-action drop
