copy flash scp
yjdabear
Does anyone have any guesses why the following fails?
catalyst6k> (enable) show flash
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
1 .. ffffffff 7058d528 9c492c 24 9717932 Aug 11 2005 01:01:20 cat6000-sup2k8.6-4-4.bin
2 .. ffffffff f75164b7 132a384 24 9853400 Mar 17 2006 19:50:52 cat6000-sup2k9.6-4-4.bin
12409980 bytes available (19571588 bytes used)
catalyst6k> (enable) copy flash scp
Flash device [bootflash]?
Name of file to copy from [cat6000-sup2k9.6-4-4.bin]?
IP address or name of remote host [tftp-server.company.com]?
Name of file to copy to [cat6000-sup2k9.6-4-4.bin]?
Username for scp[router-user]? username
Password for User username[]:
Error while uploading - Authentication Failed!
Tried multiple accounts, all with the same auth failure. FWIW, "copy flash ftp" works. Normal scp between UNIX hosts works. SSH is enabled.
b.speltz
Level 4
Level 4
Thanks. Is there a link for CatOS? I can't seem to find one. It appears I'd need the CatOS equivalent of IOS "ip scp server enable".
