CPI 1.3 error after ncs cleanup
holzhirt1
Dear all,
After I launched the ncs cleanup function I got the following issue when clicking on a AP name for i.e. :
There was an error while parsing and rendering the content. (Object #
has no method 'getAttribute')
Sometimes it is also :
There was an error while parsing and rendering the content. (Tried to register widget with id==officeExtendApDialog but that id is already registered)
Impossible to get further on the monitoring or config of the AP, very annoying...
I restarted the VM same issue, I tried with IE & Firefox instead of Chrome still same issue.
Now I tried to reinit the DB, reload and put a fresh backup before the bug was present, still the same issue,
I checked CPU, MEM and HDD usage everything seems fine...
Also some other dashboard are simply not displayed...
Any help to get rid of this message would be very appreciated...
Thanks for your support
15 Replies 15
fercordovam
I've already solved with Opera 12.16 and Downgrading Firefox to Ver 24.0. I think is a detail with webkit. Be sure to make te downgrade and disable automatic Upgrades.
Dont Install Latest Version of any browser
Saludos desde Mexico
