CPI1.3: SNMP ENGINE overloads CPU with IOS 15.x
artemepishov
Hi everybody!
I've connected my c3560G which I use as Core-switch in my company to Prime Infrastructure 1.3.
And sometimes I see a CPU overload over 50% only by SNMP ENGINE process. Total CPU load at this time - up to 100%
Possibly, It's happened after IOS update from 12.2(25r)SEE4 to 15.0(2)SE2 C3560-IPSERVICESK9-M.
I've exclude some OIDs from snmp view, but problem is still exists:
PRIMEview internet - excluded nonvolatile active
PRIMEview mib-2 - excluded nonvolatile active
PRIMEview system - included nonvolatile active
PRIMEview interfaces - included nonvolatile active
PRIMEview at - excluded nonvolatile active
PRIMEview ip - excluded nonvolatile active
PRIMEview icmp - excluded nonvolatile active
PRIMEview tcp - included nonvolatile active
PRIMEview udp - included nonvolatile active
PRIMEview transmission - included nonvolatile active
PRIMEview snmp - excluded nonvolatile active
PRIMEview ospf - included nonvolatile active
PRIMEview rmon - included nonvolatile active
PRIMEview ifMIB - excluded nonvolatile active
PRIMEview cisco - included nonvolatile active
PRIMEview ciscoMgmt - included nonvolatile active
Any ideas, guys?
Vinod Arya
It is not required to remove these OID's from by adding view. Some of them are advised as best practices, but for now they may not help unless you find the root cause.
As you just updated, try to warm restart snmp engine, use following procedure :
To Disable
#no-snmp server
To Enable
eg :
#snmp-server enable traps snmp
Se if that helps. Also once try to add following OID to you SNMP View :
clmgmtLicenseInfoEntry (1.3.6.1.4.1.9.9.543.1.2.3.1)
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
If the high CPU persit due to SNMP ENGINE share the output of :
> show version
> show stacks <SNMP ENGINE PID>
You can get SNMP ENGINE PID from show proc cpu | inc SNMP ENGINE ouput.
-Thanks
Sorry for late answer...
I have downdated IOS back because of lots of bugs in IOS 15.0(2)SE2.
But I have the same issue with C1900.
#show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.3(2)T, RELEASE SOFTWARE (fc3)
#sh stacks 373
Process 373:  SNMP ENGINE
  Stack segment 0x31B50B68 - 0x31B53A48
  FP: 0x31B53998, RA: 0x23CB52FC
  FP: 0x31B53A10, RA: 0x23EFB2C0
  FP: 0x31B53A28, RA: 0x23EFB2A4
What can I do to minimize CPU utilization?
You have to share additional details. And we need data when CPU is high for your device :
> show proc cpu sort | excl 0.00%
> show stacks <SNMP ENGINE PID*>
> show snmp stats oid
> show ip socket | in 161
> show snmp (3-5 times in gap of 2-3 seconds)
> show run | include snmp
If the device goes on high CPU randomly, you can configure a EEM scritp for this output to be collected when CPU spikes.
-Thanks
