Creating an Advanced Baseline Template
oalvi
Level 2
Level 2
How to use an Advanced Baseline Template (LMS 2.6 RME 4.0.5) to reomove or change as example "interface description" on the list of routers
Here is a template you can import that should do what you want.
5 Replies 5
Joe Clarke
Interface description isn't something typically changed en masse since each one will generally be unique. However, if you have a bunch of spoke routers, and each have a Serial0 interface (for example) that attaches back to a head end, you could do something like:
SubMode: interface Serial0
+ description Connection to Head End
For all routers that did not have this description under interface Serial0, they would be marked as non-compliant, and you could then deploy this change to them.
Good Example, if all routers marked as compliant, how I can to remove it
Assuming all the descriptions are the same:
- description Connection to Head End
If you don't want any inerface description:
- [#description .*#]
I tried to build advanced template but not succeeded.
Could you please give full steps to build advanced template to remove the Description from Ethernet Interfaces on the different routers
