Creating new User Password too short issue for NX OS for Nexus 9300
shrenit
I am trying to configure new switch Cisco Nexus 9300 with NXOS 9.3(3) and trying to add new User but not able to create new user with Error Password is too small.
Currently Password Strength check and Password secure mode is disable  on Switch.
balaji.bandi
can you post below
#show password Strength-check
password syntax you used ?
BB
Switch(config)# show password strength-check
Password strength check is disabled
Switch(config)# show password secure-mode
Password secure mode is disabled
Switch(config)# username admin1 password Shren!t1@#
Password too short
VPIM-Switch(config)#
the bug below used to be around, chances are that it still is (although your NX-OS version is not specifically listed):
Disabling password strength-check does not take effect
CSCuw28430
Description
Symptom:
On a Nexus 5000/5500/5600/6000, disabling password strength-check may still cause weak passwords to be rejected.
Conditions:
This is seen after configuring 'no password strength-check'.
Workaround:
Use strong passwords.
Alternatively, copy pasting the encrypted password directly from a different device also is accepted.
Known Affected Releases: (3)
7.1(0)N1(1)
7.1(1)N1(1)
7.2(0)N1(1)
Known Fixed Releases: (3)
7.1(3)N1(1)
For security reasons, Cisco currently has a minimum size of passwords since this prevents attacks on your network infrastructure, please rate this answer as this motivates you to continue supporting.
