Creating Switch ACL in Prime Infrastructure 2.0
alex.dersch
Level 4
Level 4
any idea if it possible to create a cli template to deploy access lists for switches and routers. It should be possible to define source and destination ip addresses as well as multiple line.
thanks in advanced
Alex
AFROJ AHMAD
Hi Alex,
Yes ,it is possible. you can check the below link:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/1-2/user/guide/prime_infra_ug/create_temps.html#wp1124827
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Alex,
Thanks-
Afroz
thanks Afroz, you saved my day.
regards
Alex
