Credential Verification Report
raghu.umesh
Community Member
The Credential Verification Report provides a way of checking if the credential used to access devices on the network are OK and that the switches and routers can be reached using this information.
However we can only view a report which at most times based on checks made by CW/RME some time ago.
My question is how can we run a check as and when required and then view these results in the Credential Verification Report.
Raghu
viswanathan123
Level 3
Level 3
Hai,
Yes this can be done in the foloowing steps.
Click Device troubleshooting -> Device center
Select the appropriate Device from the device selector.
From the right side pane select Functions available -> tools -> Management station to device
Select ALL and click OK.
This will execute all the credentials verification immediately and give you the output.
Hope this information is useful if so dont forget to rate this.
Note: This cannot be done for large no of devices at a time since you can able to select only one device at a time in device selector
