Crypto-4-recvd invalid spi
I know from someone else we are getting many messages like the one seen below.  However when I try to run sh log on a 3945 I do not get these messages...
%CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=yy.yy.yy.yy, prot=50, spi=0x56F5C9F7(1458948599), srcaddr=xx.xx.xx.xx, input interface=Tunnel172149
Can you provide settings needed for these messages to show up on syslog or steps to get them?
Thank you
johnd2310
Level 8
Level 8
What are you logging setting? You can get these from the "show logging" command.
John
**Please rate posts you find helpful**
Richard Burts
This message relates to running an IPSEC tunnel. Can you verify that your 3945 is successfully running an IPSEC tunnel?
Rick
Rick
johnd2310
Level 8
Level 8
John
