CSM and CWLMS.. integration?
marcoriosbazan
I have CSM and CWLMS servers implemented in the network, i need
to integrate the common services modules of both.. There is a possibility?
Somenthing of Multi-Trust Server..
And for the license of CS module of CSM..
CSM 3.2 (CS 3.0.1)
CWLMS 3.0 (CS 3.1.1)
Joe Clarke
You can integrate the DCRs of these two servers as well as setup Single Sign-On between the two. The LMS server must be the DCR master and SSO master since it is running the latest version of Common Services. DCR master/slave can be configured under Common Services > Device and Credentials > Admin > Mode Settings. See the context-sensitive help there for more details on the prerequisites.
Single Sign-On can be configured under Common Services > Server > Security > Single Sign-On Setup. Again, see the help for more details.
hmm.. thank you...
I have the ACS integrated with the CSM and the CWLMS too.. and both possess Common Services ..
I like to divide the permits ..
For example:
The administrator of CWLMS is not the Administrator of CSM, but in "Shared Profile Components" on the ACS, Exist only one Common Services .. I can not split them?
THanks!
