I have a probleme with a CSM configuration to upload from a PC a proxy_pac, here is the config I have:
vlan 5 client
ip address 10.255.5.6 255.255.255.0 alt 10.255.5.8 255.255.255.0
gateway 10.255.5.1
route 10.236.21.13 255.255.255.255 gateway 10.255.5.1
vlan 6 server
ip address 10.255.6.6 255.255.255.0 alt 10.255.6.8 255.255.255.0
gateway 10.255.6.1
vlan 329 client
ip address 10.255.29.34 255.255.255.0 alt 10.255.29.36 255.255.255.0
gateway 10.255.29.1
vlan 829 server
probe PROXY_PAC http
request method head url http://10.255.29.9:8081/accelerated_pac_base.pac
expect status 0 499
interval 8
retries 2
failed 10
port 8081
serverfarm PROXY_PAC
nat server
no nat client
predictor leastconns
real 10.255.29.23
no inservice
real 10.255.29.22
inservice
real 10.255.29.21
inservice
probe PROXY_PAC
And when a put the proxy in IE it stays stock.
Do you have any ideas ?
Do someone did expereience de same problems.
Cheers
Blaise
PS looking at the connections on the CSN doing a: sh module contentSwitchingModule 1 conns
I can see that the connections are established
