CTM corba gateway problem connexion through IBM Netcool CTM probe
pvignaud
We're trying to query the CTM Corba Gateway installed on a CTM server v9 through a CTM probe designed to work with the IBM Netcool solution.
The CTM Corba is installed correctly :
(dksjdks) #showctm -v
CTM Processes for
Cisco Transport Manager Server Version: 9.0 Build: 604 Patches: 2
USER   PID   %CPU       %MEM          START         TIME  PROCESS
root  20583  0.0   0.711092028792     Mar_24      116:29  CTM Server
root  20548  0.0   0.399824           Mar_24        0:00  CTM Server
root  20910  0.5   7.0616600285016    Mar_24      120:16  SnmpTrapService
root  20709  0.1   4.7431200189936    Mar_24       21:09  SMService
root  20940  0.3   12.71131488517656  Mar_24       27:13  CTC-based SONET NetworkService-2
root  20956  0.1   6.4516024259992    Mar_24        4:26  ONS15454/ONS15327/ONS15310CL/ONS15310MA PMService-1
root  7640   0.1   7.5830336307864    11:42:13      0:25  CORBAGWService
root  7517   0.1   2.520609699184     11:41:59      0:54  NotificationService
root  6745   0.1   2.121805683936     11:34:41      0:19  NameService
root  20288  0.8   3.9223232157704    Mar_24       86:42  JBOSS JMS
root  20562  0.0   0.1                Mar_24        0:19  Apache Web Server
Check the debug information below, when a request is generated fron the CTM probe (solaris box) :
ds:/home1/alu> /opt/netcool/omnibus/probes/nco_p_cisco_ctm_corba_v9 -messagelevel debug -messagelog stdout
03/31/10 18:53:16: Information: Connecting ...
03/31/10 18:53:16: Debug: Reading /opt/netcool/omnibus/probes/solaris2/cisco_ctm_corba_v9.rules
03/31/10 18:53:16: Debug: Plain text rules file detected.
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 1 has zero columns! (########################################################################)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 2 has zero columns! (#)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 3 has zero columns! (# Licensed Materials - Property of IBM)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 4 has zero columns! (# )
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 5 has zero columns! (# 5724-P16 )
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 6 has zero columns! (# )
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 7 has zero columns! (# (C) Copyright IBM Corp. 2007. All Rights Reserved)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 8 has zero columns! (# )
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 9 has zero columns! (# US Government Users Restricted Rights - Use, duplication)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 10 has zero columns! (# or disclosure restricted by GSA ADP Schedule Contract)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 11 has zero columns! (# with IBM Corp.)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 12 has zero columns! (#)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 13 has zero columns! (########################################################################)
03/31/10 18:53:16: Warning: ../includes/ManElement.lookup: line 14 has zero columns! ()
03/31/10 18:53:16: Debug: Lookup table from '../includes/ManElement.lookup' has 4 columns
03/31/10 18:53:16: Debug: End of /opt/netcool/omnibus/probes/solaris2/cisco_ctm_corba_v9.rules
03/31/10 18:53:16: Debug: Number of currently connected servers in list is 0
03/31/10 18:53:16: Information: Using targets specified by properties
03/31/10 18:53:16: Debug: Creating target for server COL_HYDRO_P.
03/31/10 18:53:16: Debug: Setting default target server to 'COL_HYDRO_P'.
03/31/10 18:53:16: Debug: Default target backup server is ''.
03/31/10 18:53:16: Debug: Primary server is 'COL_HYDRO_P' backup is ''.
03/31/10 18:53:16: Debug: Attempting a connection to server 'COL_HYDRO_P'.
03/31/10 18:53:16: Debug: Checking for backup ObjectServer.
03/31/10 18:53:16: Information: 'COL_HYDRO_P' is a primary server. Polling disabled.
03/31/10 18:53:16: Debug: Checking for svc update support.
03/31/10 18:53:16: Debug: Server SUPPORTS services.
03/31/10 18:53:16: Debug: svc update SUPPORTED
03/31/10 18:53:16: Debug: Server Verification Starting.
03/31/10 18:53:16: Debug: Server Verification Complete.
03/31/10 18:53:16: Debug: SAF: Forwarding SAF file on Initial startup
03/31/10 18:53:16: Debug: SAF: Disconnectiontime = 0 : Expire time = 0
03/31/10 18:53:16: Debug: SAF: Forwarding events from SAF files
03/31/10 18:53:16: Debug: Heartbeat mode is: standard
03/31/10 18:53:16: Debug: Heartbeat mode is standard, probe will function as normal without heartbeating
03/31/10 18:53:16: Debug: Final number of connected servers in list is 1
03/31/10 18:53:16: Debug: NSProbe - Reentrant Version
03/31/10 18:53:16: Debug: *NOT* running PA Aware
03/31/10 18:53:16: Debug: FlushBufferInterval-> 0
03/31/10 18:53:16: Information: Probewatch: Running ...
03/31/10 18:53:16: Debug: Flushing events to object server
03/31/10 18:53:16: Debug: Initialising connection to Cisco Ctm system
03/31/10 18:53:16: Debug: AgentHeartbeat-> 60
03/31/10 18:53:16: Debug: Timeout-> 0
03/31/10 18:53:16: Debug: EncodingStandard-> ISO-8859-1
03/31/10 18:53:16: Debug: GetPublicKey-> 0
03/31/10 18:53:16: Debug: ReactOnStateChange-> 0
03/31/10 18:53:16: Debug: Connecting to interface object
03/31/10 18:53:16: Debug: Attempting to create new CorbaUtil object
03/31/10 18:53:16: Debug: ORBInitialHost->
03/31/10 18:53:16: Debug: ORBInitialPort-> 1570
03/31/10 18:53:16: Debug: Creating VisiBroker ORB
03/31/10 18:53:17: Debug: Successfully created new CorbaUtil object
03/31/10 18:53:17: Debug: Attempting to get reference for interface object
03/31/10 18:53:17: Debug: IORFile->
03/31/10 18:53:17: Debug: NamingContextIORFile-> /opt/netcool/omnibus/probes/solaris2/NameSingleton-2010-03-31.ior
03/31/10 18:53:17: Debug: Attempting to get object reference via Naming Service IOR file
03/31/10 18:53:17: Debug: Will attempt to load Naming Service object reference from IOR file : '/opt/netcool/omnibus/probes/solaris2/NameSingleton-2010-03-31.ior'
03/31/10 18:53:17: Debug: Converting string IOR to reference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
03/31/10 18:53:17: Debug: Converted (Stub[repository_id=IDL:omg.org/CosNaming/NamingContextExt:1.0,key=ForeignId[key_string=OpenFusion.NameService/OpenFusion.NameService/!%c3%bb%e8p%c2%8e%11%de%9bI%a0bZ%c5%c3%90%c1%f3%0fP%c2%8e%11%de%9bI%a0bZ%c5%c3%90],codebase=null])
03/31/10 18:53:17: Debug: Successfully found Naming Service object reference
03/31/10 18:53:17: Debug: Attempting to resolve Naming Context to object reference
03/31/10 18:53:17: Debug: NamingContextPath-> services/NotificationService
03/31/10 18:53:17: Debug: Narrowing reference to NamingContext
03/31/10 18:53:17: Debug: Successfully narrowed reference
03/31/10 18:53:17: Debug: Resolving Object reference
03/31/10 18:53:17: Debug: Resolved Object reference
03/31/10 18:53:17: Debug: Successfully found object reference
03/31/10 18:53:17: Debug: Narrowing object reference to interface object
03/31/10 18:53:17: Error: Failed to narrow object reference : org.omg.CORBA.BAD_PARAM: vmcid: 0x0 minor code: 0 completed: No
03/31/10 18:53:17: Debug: Check that IOR files are correct and up to date
03/31/10 18:53:17: Error: Failed to get object reference : org.omg.CORBA.BAD_PARAM: vmcid: 0x0 minor code: 0 completed: No
03/31/10 18:53:17: Error: Failed to connect to interface object : org.omg.CORBA.BAD_PARAM: vmcid: 0x0 minor code: 0 completed: No
03/31/10 18:53:17: Information: Probewatch: Unable to get events
03/31/10 18:53:17: Error: Unable to get events:
03/31/10 18:53:17: Debug: Flushing events to object server
03/31/10 18:53:17: Debug: Retry-> false
03/31/10 18:53:17: Debug: Retry is false - will not reconnect
03/31/10 18:53:17: Information: Probewatch: Going Down ...
03/31/10 18:53:17: Debug: Flushing Session
We receive an error message from an object reference.
Does it tell you something ?
Thanks.
Patrick Vignaud.
0 Replies 0
