Customize roles in ciscoworks
martin.belisle
Hello, is it possible to customize user roles or rights in CW?
For example when I create a new user, I have a choice of the following pre determined roles:
-helpdesk
-approver
-Network operator
-network administrator
-system admin
-export data
So is it possible to create customs one that would only give access to what I choose?
thanks
David Stanford
If you are using CiscoWorks in Local mode then you cannot customize these roles. If you want to customize and be more specific with permissions you will want to integrate CiscoWorks LMS with ACS. This will allow you to create more custom roles and privileges.
Thanks for the info.  We are in local mode.
