Customizing/Adding Events In DFM
cganderson14
Does anyone know if it is possible to add event codes to DFM? That is; are the event codes in CiscoWorks DFM only system defined or can user defined codes be input? Specifically, I would like to be able to have an event trigger when the MLS-4-MOVEOVERFLOW message occurs on any switch.
