Customizing performance threshold for interface utilization in LMS 4.0
wwanjohi123
Level 3
Level 3
Am running LMS 4.0, i want to customize performance threshold for interface utilization from the default 40% to x%, please help.
Joe Clarke
Based on your other post, I think you're talking about Device Fault management.  You can go to Monitor > Fault Settings > Setup > Threshold Settings, and select the DFM > System Defined Groups > Interface and the interface type you want, then edit the thresholds for this group.  Change the default utilization threshold from 40% to your desired value.  Save your changes, then go to Monitor > Fault Settings > Setup > Apple Changes to apply them.
