cw rme problem
dragec
Level 5
Level 5
when I make report in RME, and choose inventory and user defined group (created over common services, group, group admin), report is made but several devices I've added recently are not included. Like RME does not read common services database correctly or something. How can I degun this?
5 Replies 5
Joe Clarke
What version of RME is this?
not sure .... latest in LMS 2.6 I think
Assuming you do have RME 4.0.6, recreate your report, but select the "Group Selector" radio button above the device selector. Then, choose the group for which you want the report to run. As you add and remove devices, the report will update to reflect the new devices in the specified group.
it didn't help
I solved it. Some devices were in conflicting state in RME and because of that they have not been taken into reports
