cw tomcat servlet engine
dragec
on my cw server tomcat servlet engine does not start. Wich log cany try to look at in order to see what is the problem?
br
Joe Clarke
NMSROOT/MDC/tomcat/logs/stdout.log
Of course, there may be some hs_err* files in NMSROOT/MDC/tomcat or errors in the Windows Event View (on Windows).
:-)) this does not look good. I think I will start to look something else Any ideas after reading this log?
Your NMSROOT/MDC/etc/regdaemon.xml file is corrupt (most likely 0 bytes). You either have to restore a known-good backup of this file, or reinstall all of LMS from scratch.
