cw2k v4.0 discovery problem
macaudill
I am having problem with User tracking not reporting the users on the correct port. It is reporting users on the global up-link port. Is there something I need to do with configuration on the CAT1900's, 2900's, 3500's to keep cw2k from discovering users on these ports?
umedryk
Level 5
Level 5
There is no specific configuration requiered. They should be automatically discovered.
